Is a 9bolt yoke the same as a 10bolt?
Old Jun 1, 2005 | 05:32 PM
just2quickz28's Avatar
Car: 86 IROC
finally get my car drivable after 4 years and i destroy the old universals, one of the bolts that hold the drive shaft to the yoke broke. i attempted to drill and retap and ended up with a tap broken in the yoke, i have the old burned out 10 bolt rear at the garage and was wondering if the yokes were the same>
matt
Old Jun 1, 2005 | 07:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're both Saginaw yokes, I believe. That doesn't mean the pinion shafts are the same though.
Old Jun 5, 2005 | 12:22 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
yes id like to know also if the 9bolt yoke is the same as the 10 bolt. lol the same exact thing happend with the tap with me... sucks!... is it the same size/ number of splines? also has anyone made a rear diff cover yet for the 9bolts?
Old Jun 6, 2005 | 06:09 PM
Car: 86 IROC
ill find out this weekend, crush sleeves should be in from Ratech so i can pull the other yoke out, when i attempt it, ill let ya know
Old Jun 26, 2005 | 09:43 AM
Car: 86 IROC
well no go on using the 10 bolt yoke.........dont match up at all, any ideas on where to get a new yoke? driveshaft company over here couldnt save the yoke?
Old Jun 26, 2005 | 11:54 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
9bolt.com ?
Linson
Nov 12, 2015 08:09 PM
gord327
Sep 29, 2015 10:18 PM
FastBroker
May 23, 2001 08:00 AM
True Power
Dec 8, 2000 08:17 PM
MikeT 88IROC350
Oct 21, 2000 04:28 PM
