Reverse Gear
Old Jun 2, 2005 | 10:58 AM
Puntman87's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5-Speed
Reverse Gear
So ummm I dropped my clutch red lined in reverse... yes I now know that it was quite stupid, but for some reason I need to learn everything the hard way... Now my car wont go into reverse... it goes into reverse and then when I let off the clutch it pops into neutral... I tried manually holding the shifter and it stays in reverse but makes a lot of gear grinding noises... this there a way to fix this or do I need to either get a new tranny or have a car with no reverse gear?
Old Jun 6, 2005 | 10:56 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You need to pull the trans and have it fixed. Something was damaged internally (reverse gear ont eh 1/2 slider, reverse idler, or the reverse teeth on the countershaft). I can fix it if you can't do it yourself. PM me.
GTAman
Jul 3, 2024 07:29 PM
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
