tranny cooling lines--which is in + out?
Old Jun 10, 2005 | 01:53 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Somebody refresh my memory PLEASE. On a 700R4, the 2 cooling lines on the passenger side of case, is it:
top line at tranny itself is return?
bottom line at tranny is send or pressure side?
THANKS
Craig
Old Jun 10, 2005 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Bottom line is out from the transmission, into the cooler. Top line is out of the cooler into the transmission.
Old Jun 5, 2006 | 04:35 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
So the bottom line out of the tranny goes to the top of the rad,correct? Then bottom of rad goes in the top line on the tranny?
Thanks,
Conrad
Old Jun 5, 2006 | 04:57 PM
Shagwell's Avatar
Car: projects.......
No, out from the trans goes to the bottom of the rad. You always feed from the bottom to the top to avoid possible air pockets.
Old Jun 5, 2006 | 06:02 PM
twobirds's Avatar
Car: 1987 GTA 350
Thanks man that helps me alot!!
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
