10 bolt vs 12 bolt
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
10 bolt vs 12 bolt
I wanted opinions on the 10 vs 12 bolt GM rear ends. It is for dirt circle track, I've seen the c clips bust on the 10 bolts and I can't get anthing close to a .600 ring and pinion in the 10 bolt.
Is the 12 bolt much of an improvement or is the 9 inch ford the way to go? I know ford is a dirty word but FMC has to have done something right over the years.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nothing wrong with using a 9" if you're allowed to. Some classes won't let you swap parts from different brands.
The strength of a 9" and 12 bolt is close enough to same they're the same. They both have advantages and disadvantages from each other. It just depends what you need or want.
GM produced 3 different 10 bolts. The 8.5" is the most popular being almost as strong as a 12 bolt. The 8.2" was a short lived version. The current and weakest is the 7.5/7.625" found in third and fourth gens, S10's, Astro vans etc. It's not a performance diff and there is very little performance parts available. No matter how much you try to beef it up, it still has the tiny ring and pinion. I've run a beefed up 10 bolt into the low 11's on the 1/4 mile.
A complete direct bolt in 12 bolt or 9" is around $2500 for a third gen.
I noticed I posted on the wrong page and put it on the correct one. Am I being chastised? I didn't mean to inconvience you by asking a question on the wrong board.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
