clutch hydraulic problems
Old May 19, 2005 | 10:50 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Ok... everything is together but my pedal is moosh. I have tried bleeding this thing and I am going to try again tomorrow... my system doesnt apear to leak anywhere... is there anything that is suposed to secure the hose for the reservoir? in both places? hose to reservoir and reservoir hose to master cylinder? could I be losing pressure in those places ?
Old May 20, 2005 | 07:27 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you're loosing pressure you'd have a leak. How'd this situation develop? The system is sealed, so there shouldn't be air in the system unless something is broken.
Old May 20, 2005 | 08:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
People always seem to be in a hurry to blame the hydraulics for EVERYTHING that goes wrong with their clutch.
They are rarely at fault. If they haven't exploded, and they hold fluid, then the problem is elsewhere.
Which is of course why "bleeding" them had no effect.
I'd suspect incorrect assembly somewhere.... clutch fork not on the pivot ball correctly, or not in the throwout bearing groove correctly.
Old May 20, 2005 | 08:31 AM
i supose i should mention that it seems to have an endless supply of air bubbles? (i am reverse bleeding) it firms up a little and i am able to get 2nd gear with the car running when i have the pedal all the way down. Seeing as I have never done this before how long is reasonable for getting the damn air out with a hand pump? I am pretty sure everything else is setup ok. I just doesnt seen that there is much travel at all with the slave
Old May 20, 2005 | 08:34 AM
oh... one more thing... this a t5 SWAP from an auto so i dont have the luxury of knowing that the hydraulics were already properly bled. or even working
Old May 20, 2005 | 08:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well that's an additional variable.... no telling what might have happened to it along its path from wherever it was to where it is now.
If you just let the slave cyl hang for a day or so from the line, it will pretty much bleed itself. Make sure it's topped off with fluid.
As long as it wasn't disassembled it shouldn't need bleeding. FYI, the factory ships the whole deal as a complete assembly (MC, SC, reservoir, & line), in a box, filled with fluid, pre-bled. You just take it out of the box and install it.
If somebody disassembled it, then who knows what might have happened to it. You might be better off to just go down to the dealer and get a new one.
Old May 20, 2005 | 09:06 AM
when i got it, the tube going to the reservoir and the reservoir itself were not attached and now, they are just sliped on where they are suposed to be. is there enough pressure in the system where this could be a problem? would some hose clamps help? I REALLY dont want to have to pull all of this crap out if i dont have to.
Old May 20, 2005 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no pressure there; the little squeezy type hose clamps are all that the factory uses.
You shouldn't be afraid of pulling it back out if you need to. It only takes about 30 minutes to change that whole assembly out, from tow-in to drive-out.
Old May 20, 2005 | 09:36 AM
so i assume you remove it with out taking the brake booster out?
Old May 20, 2005 | 09:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
Why in the world would you want to do extra work like that?
Old May 20, 2005 | 01:21 PM
A complete new assembly from GM is about $90, and just like RB said it is ready to install.
If you are bleeding it I would say it shouldn't take long to get the air bubbles out. If they persist you've got another problem. I'd take RB's advice though and let it gravity bleed. That's the best way to bleed hydraulics if you've got the time.
Old May 20, 2005 | 03:54 PM
im gonna try the pump again today then maybe let it gravity bleed over the weekend. I will just barely crack the bleeder and leave a bottle of brake fluid upside down in the reservoir.
Old Jun 14, 2005 | 10:13 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I'm having a similar problem with my T5 swap. The pedal is floppy until the very bottom where it begins to stiffen up. How is the throwout bearing supposed to be on the fork? I have it so that the lip closest to the transmission is under the spring like metal tab. the result seems to be that the fork pushes forward until it hits the front edge of the bearing where it pushes in the clutch. is this wrong?
Old Jun 14, 2005 | 10:14 PM
Car: '85 TA
sorry to awaken an older thread....i didnt see it 'till it was too late
Old Jun 15, 2005 | 08:19 AM
my problem turned out to be a tweeked clutch fork... got a new one from napa and everything worked fine
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
