700r4 in a pre ecm vehichle
Old Jun 14, 2005 | 03:15 PM
91V8Redbird's Avatar
Car: 91 V8 Firebird
Engine: LO3 305 TBI V8
Could a 700r4 be run in a pre ECM (non computer controlled) vehichle, and would it still shift properly and go into overdrive?
Old Jun 14, 2005 | 05:58 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
You would still need a TV Cable and some way to lock up the converter (I'm using a TCI Vacuum lockup kit).
Old Jun 14, 2005 | 10:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The TCI vacuum kit is nothing more than what GM used in the carbed vans and trucks.
Old Jun 14, 2005 | 11:13 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It was used on the Canadian carbed F-bodies which were not CC'd either. My 84 has one.
Old Jun 15, 2005 | 10:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Option 1: Run a non-lockup converter and converter the trans accordingly (very easy).
Option 2: TCI vaccum lockup kit
Option 3: Electronic lockup system, check the tech section on TGO, it will show you how to build one for very little money
Option 4: Hydraulic lockup kit
skeltor
Feb 2, 2016 10:37 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
customblackbird
Oct 1, 2015 04:30 PM
