speed related vibration and how to check pinion angle
Old Jun 16, 2005 | 11:09 PM
TexasLT1's Avatar
Car: '92 RS
Background: For the past 2 weeks I've been working on swapping in a T-56, Spec Stage 3, and 4.11 gears. I had the driveshaft dynamically balanced at Houston Driveshaft as well as had new Spicer U-joints put in. I also made my own swap crossmember.
Today: I finally got the car on the road, just been taking it easy around town to break in the clutch. I took it out on the highway earlier and ran it up to about 70, but at 65-68 a fairly bad vibration picks up, high frequency and definitely related to vehicle speed. I pulled it into the shop hoping it was one of the wheels out of balance, so I set it up on jack stands, removed the wheels, ran it up to 70, vibration still there. I saw another post about turning the driveshaft 180* in relation to the pinion yoke, but that didn't help either. The only thing left I can think of is either pinion angle or front yoke.
When I made the crossmember I measured the distance from the ground to the center of the output shaft of the T-5 before I removed it and did the same to the center of the T-56 output shaft. How much off at this place would it take to affect the pinion angle? 1* isn't a whole lot, especially over that distance. How much off would the pinion angle have to be to cause a vibration?
Old Jun 17, 2005 | 11:12 AM
TexasLT1's Avatar
Car: '92 RS
ok, went and got an angle finder from the hardware store.
-3*. I've heard -1 to -2 is what you want for the street. 1 degree isn't a whole lot, but would that be enough to cause the vibe?
lt1z350
Sep 29, 2015 01:50 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
89fast5oh
Aug 24, 2015 08:14 AM
spaigo
Aug 21, 2015 07:46 PM
86IROC112
Aug 21, 2015 07:20 PM
