leaky tranny pan, easy fix?
Old Jun 18, 2005 | 05:54 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
can i just pull the cover and replace the gasket? while i've got it open i should also replace the filter right? is this hard to do, and is there anything else i will need to do, or should do while i have it open? bear in mind, im a novice and i dont want to fiddle around too much with the inside of my transmission. its a 700r4 with a b&m street/strip shift kit. would it be worth the investment to get a new pan or anything like that while i'll have it apart anyhow?
Old Jun 18, 2005 | 09:06 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
If it is leaking from the pan, yeah, just drop the pan off, take the filter out, clean the tranny and pan off, and reassemble. The torque sequence and torque specs are important to follow if you dont want it to leak. Cross tighten all bolts to 12 foot pounds, no more, and after about 500 miles, retighten them once more to ensure proper seal.
Old Jun 18, 2005 | 10:50 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Be sure to look closely at the pan where the gasket sits. Sometimes they are overtightened and it warps the pan rail. If so, a few careful whacks with the hammer will put it back in shape.
Dkelz313
Apr 7, 2016 10:38 PM
hydrolic144
Sep 4, 2015 09:48 PM
z28guy134
Sep 1, 2015 11:50 PM
Thornburg
Aug 25, 2015 01:46 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
