clutch not staying in adjustment
Old Jun 19, 2005 | 12:24 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
seems like after the car has reached temp. the clutch wont release ... kinda like hydrolic fade cept its not hydrolic ... i can adjust it and its fine till the next morning when i first get going it feels like its slipping so i adjust it and it all starts over been under there a hundred times every thing looks the same as always ... the rod bettween the bell crank and throw out bearing fork is locking in place just fine ... any body have a clue? thx .... tao
Old Jun 21, 2005 | 02:26 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
So, everything is fine until the car gets up to operating temperature, and then the clutch won't work? You go under the car, adjust the clutch linkage and presto it works again?
Is the linkage losing the adjustment? In other words are you just setting it back to the same position every time, or are you actually changing the length of the rod every time?
If you've got a T5 one thing that could cause a problem like this is if the rear bearing retainer is scored. Essentially the throwout bearing is getting hung up on the retainer. A new on is $45, but you've got to pull the trans, and you really should check the mainshaft endplay since it's a new part.
Old Jun 22, 2005 | 12:52 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
thats what it seemed like ... but tonight i pulled the bell crank and all the related linkage ... i found that the hole in the cluch pedal was elongated i suspect that to be the real problem as it was letting the rod catch at differant places in the hole ... as i got lazyer in pushing on the pedal it would change ie. from the side instead of stright its gonna be a real pita to fix because of the roll bar but im pretty sure thats where the problem lies... or at least a part of it ... if i do pull the tranny for another reason i will be sure to check the retainer as you have advised ... thank you for your responce ... tao
gta892000
Aug 11, 2019 11:16 AM
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
