hydraulic clutch mod!!!
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
I just read an article on drilling out the restrictor in the f body hydraulic clutch. It apparently seriously helps slippage when shifting hard through the gears. Can someong give some better instructios on this or maybe pics please??
http://www.motownmuscle.com/forums/a...dex.php/t-4674
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I would do a search on camaroz28.com on this, I used to have a link but not anymore, you'll find it there though.
This mod is pretty easy to do though, just hammer out the roll pin on the slave with a small punch or even a nail, Then I think I used a 1/8" drill bit to drill out the restrictor in the line comming to the slave, its right at the end where the fitting is. Make sure you blead the system before you put it back!
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
This only applies to the LS1 hydraulics. Earlier units did not use the restrictor.
Car: 89 GTA
1989, 2010, 89, camaro, clutch, ends, gen, hydraulic, hydraulics, line, mod, modification, restriction, trans, whereis
