quik easy question about axles
Old Jun 22, 2005 | 04:13 PM
superirocz's Avatar
I never had my 9 bolt rear apart. I will be putting different backing plates on my 88 9 bolt to run the pbr brakes so need to pull the axles out. I would asume I have to pull the diff cover of the back and unbolt something to let the axles slide out, what might that thing be?
Old Jun 22, 2005 | 04:31 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
you have to remove the retaining bolt that holds that big pin in place. then you can remove the c-clips and remove the axles.
Old Jun 22, 2005 | 07:17 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you do not need to remove the cover on a 9 bolt. simply remove the 4 bolts/nuts on the axle flange and pulll the axle out.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Oct 7, 2015 08:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
