LT1 4l60E to t56
Old Jun 26, 2005 | 11:25 PM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
LT1 4l60E to t56
First off, I've searched quite a bit on this topic, without the answer I need, but...If anybody knows of a thread that answers my question, please post a link to it! I hate to repeat material that's already been covered.....
I have a complete 95 LT1 motor, 4L60E tranny & harness to be swapped into my next project car (the tranny's blown). My question is, if I change to a t56, what do I do with the wiring? I've read the posts on how to wire the t56, and I understand that. I want to know what to do with the big ol' plug that goes in the side of the 4l60E. Do I just leave it hang there? If I change the info in the pcm, to a stick instead of auto will this be ok? I just don't want to go through all of the trouble to find out that I get a check engine light over a disconnected plug.
Thanks in advance,
-Mike
Old Jun 27, 2005 | 07:22 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you alter the PCM to know that you have a T56 instead of an auto it shouldn't be a problem. Sounds like you will need a bit of custom tuning. I would see about having the skip shift stuff removed completely for the T56, too. That's just some stupid gas milage thing they did that. Basically you just need the PCM to run the engine.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
