rear end switch??
Old Jul 1, 2005 | 03:03 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
rear end switch??
i have a 91 305 rs camaro. the rear end i have new is the 2.73 std rear end. and i have a friend that is willing to sell me the whole rear assembily. drum rotors, shafts and all. it is off either a 85 or 86 camaro. not sure which one. and it is limited slip. i was just wondering if this would fit onto my car, and how i would go about doing this. any help would be great. thank you. -jon
Old Jul 1, 2005 | 03:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All third gen diffs from 82-92 are direct bolt in to any other third gen. Even a fourth gen diff is a direct bolt in however the fourth gen diff is about 2" wider on each side so proper backspace wheels are required.
The only difficulty in the swap would be if you're swapping from drum to disk brakes or the other way around. The park brake cables are different.
Your 91 is a better diff since it will have a 7-5/8" ring gear compared to the earlier 7-1/2". Your 91 will also have 28 spline axles and the earlier ones have the smaller 26 spline. It would be better if you just buy a new posi and the gear ratio you want and install it into your diff.
Old Jul 1, 2005 | 05:08 PM
they are both drum brakes. and the reason i am switching them is because this one is a limited slip and my current isn't. also i am only getting it for 75 dollars. my friend needs money, thats why it is cheap.
Old Jul 1, 2005 | 05:09 PM
also what all would i have to do to switch them. i know i will have to disconnect the breaks and take off the shocks. is there anything else i would have to do?
Old Jul 1, 2005 | 06:16 PM
acctually i forgot, it is coming off of a 79 z28. would it still bolt up good?
Old Jul 1, 2005 | 08:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The '79 diff won't work in your car. Nothing is the same.
The housing is designed for a leaf spring car and yours uses a torque arm system.
The second gen diff is too wide even if you could find some way to adapt it.
The second gen 10 bolt is a 8.5" ring gear so you couldn't even take the gears and posi out to use in your 7-5/8" 10 bolt diff.
Old Jul 2, 2005 | 11:03 PM
yeah i went to look at it today just to make sure, and it was made for leaf springs. so i guess i will just keep looking. thanks for all the help though!!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
