Tremec TKO
Old Jul 3, 2005 | 07:17 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Tremec TKO
can you still find the older TKO 5 speeds? i know tremec now makes the TKO 500 and 600...but i'd like to find a rebuilt TKO....any ideas?
Old Jan 17, 2006 | 09:26 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
yes you can, the older tremec even for mustangs will work, you'll just need the adapter plate to rotate the tranny. of course you'd have to find a 26 spline input shaft one. i believe national drivetrain specialties sells the adapter plate. good luck
Old Jan 18, 2006 | 07:23 AM
wdigitog's Avatar
thanks big dave...where'd you get the 3550? 4 speed? was it in a truck?was the same problem of needing to mount it slanted?
Old Jan 18, 2006 | 02:04 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Mcleod makes a blowproof bell, pn 8635, to mount the TKO 3550 to most GM V8 engines. It includes the adapter. I got one by mistake from my Tremec dealer & could not use it because the GM spec TKO 600 will bolt to a standard Chevy bell.
Old Jan 20, 2006 | 06:50 AM
wdigitog's Avatar
couldn't you use the mustang t-5 using a mustang disc in a chevy pressure plateclutch?
deracer
Apr 11, 2016 12:04 AM
topteam54
Oct 6, 2015 12:21 AM
jharrison5
Aug 19, 2015 05:53 PM
Maverick13
Jul 8, 2001 11:15 AM
Maverick13
Mar 28, 2001 09:26 AM
