tranny problem
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
tranny problem
now my car was a 6cyl 5 speed now a 383 550hp motor that i built now will the 6cyl tranny bolt up to a 8cyl bell housing or do i need a v8 tranny
thanks ryan
thanks ryan
Car: check
Engine: check
Transmission: check
The V6 trans will bolt up to the V8 bell. The input shaft is different. So, a V6 clutch disk or a custom clutch disk will be required. Several folks here on TGO have had a custom disk made up. Use a V6 hub with the V8 disk portion.
RBob.
RBob.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
