Rebuild 9 bolt or move on?
Old Jul 9, 2005 | 10:02 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
As of right now I have a perfect 9 bolt. No leaks all powercoated and perfect working 89 and up PBR brakes with Baer Rotors. BUT the posi is shot. Do I splurge and purchase and new posi from 9bolt.com and have somebody put it in, or find a 10 bolt and try to clean that up and convert the brakes and take a chance if the posi is good or not?
Old Jul 9, 2005 | 06:39 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I say rebuild it.
I was in australia last week, getting part numbers,and dealers for the posi's, gears, and LSD LUBE. The posi were easy to get, but I held off, waiting for mine to crap. Also I am not too sure about MILES's business. I have tried to contact him to see if he had parts availble in the states. NO REPLY.
I will be in the states for the next month, but after that I may get into digging this stuff up. The 9 bolt diffs are in most everything in Australia
shawn
Old Jul 10, 2005 | 12:50 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Rebuild 9 bolt or move on?
If the car is not raced, then not having posi isn't a big deal -- but if you're set on fixing it, the repair can be expensive.
Unless you're a "purist" in wanting to keep the car completely stock, the decision of what to do depends on the price of parts and labor to rebuild the 9-bolt. In my case I couldn't find a reasonably-priced mechanic to do the rear rebuild and setup and wasted $700 trying to have a friend do it. Buying the parts and having the rear setup might cost $500-800. It is far cheaper to buy a complete rear to exchange instead of going through the hassle of fixing the non-working-posi in your differential. I was able to locate three complete disk brake posi rears for about $125 each in great condition. All three have PBR and 12-inch rotors, two of them are 4th Gen and yes I like the 1.5-inches extension of 3rd Gen wheels on each side. Rather than spend lots of money to fix an old rear, I'd opt to invest a couple thousand in a 12-bolt or 9-inch -- at least then you know it won't break and parts will be readily available in the future.
Old Jul 10, 2005 | 08:07 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
My posi is shot also. I don't really want to tackle it, but am looking for another for a spare.
Old Jul 13, 2005 | 07:45 PM
Parrydise7's Avatar
I don't think I've ever heard of someone going from a 9-bolt to a 10-bolt, especially with a 383. The parts for the 9-bolt are expensive, and Miles seems to have faded away, but are you sure that you want a 10-bolt?
Old Jul 13, 2005 | 10:24 PM
Mark 89Formula's Avatar
Thought hard about this same question myself since my 9 bolt posi was basically dead. To me, it just wasn't worth throwing money into the 9 bolt. Parts are expensive and scarce and I don't have the same faith in their strength that others do. I picked up a Dana 44 but the backup plan was a 10 bolt.
Old Jul 14, 2005 | 10:31 AM
Parrydise7's Avatar
If you don't want that Dana 44, I'll be happy to take it off your hands! PM me.
Old Jul 15, 2005 | 06:01 AM
CrazyHawaiian's Avatar
Car: too many ...
Depending on how much power you're making it might be time to bite the bullet so to speak and start saving up for an aftermarket rear like a 12 bolt or something. You can only expect so much out of stock parts, even freshly rebuilt. I also have a 9 bolt with a posi on the way out and I'm not really considering getting it rebuilt. Parts are just too expensive for that rearend. I've decided to go to a 10 bolt but my situation is probably different than yours (this is a track car and I want to run a minispool and I dont care if I blow up a bunch of 10bolts, they're cheap).
Old Jul 15, 2005 | 05:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i just spent alot of money on puttin a new 3 seriies carrier in with 3.27 gears in my car
120 for the install kit, 70 for the gears, 70 for the carrier, plus installation costs since i didnt want to do that on my own
that carrier was bought over a year ago and i havent seen many aroudn for sale... from ebay to the classifieds
whenever it goes, i will go 10bolt from a 4th gen so i can ZR1 wheels
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Eric-86sc
Apr 3, 2016 03:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
AkDrifted
Aug 17, 2015 07:45 PM
