rear end swap
Old Jul 11, 2005 | 02:15 PM
joeludwin04's Avatar
Car: 1983 camaro z28
Engine: 5.0L
Transmission: 5 speed
rear end swap
i have a 83 z28 with a 10 bolt rear end. i would like to swap the rear end with a 10 bolt posi out of a 87 iroc. my questions are; Are the those two interchangable? Will the ring and pinion in the 83 work on the 87? also the 83 have rear drum brakes and the 87 has rear disc brakes, will that be a problem?
thanks for the help
Old Jul 11, 2005 | 03:17 PM
ede's Avatar
ede
you sure the 87 is a 10 bolt? if the carrier series is the same the gear set will be direct swap. 10 or 9 bolts along with a dana 44 would be direct bolt in with minor differances in brake lines, e brakes, porpotioning valve, etc.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
