Wtf!!! Tko-600 Doesnt Work With Spohn X-member?!
Old Jul 11, 2005 | 06:13 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I have the tko-600 tranny from fortes, and the spohn crossmember and torque arm for the tranny, and simply put, the tranny mount is about an inch off from where it should be. Anyone else have this problem or is there a problem with my setup? This is all being done by a very reputable shop so the workmanship is fine, im thinking there might be something wrong with my setup?
Old Jul 11, 2005 | 09:54 PM
therover87's Avatar
Car: 89 camaro ss
Transmission: TKO600
i just put that tranny in my 89 with the spohn parts mentioned and i ran into no problems at all.
Old May 4, 2006 | 10:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have this same issue. Where you using a trans with the adapter plate and stock BH?
Old May 6, 2006 | 12:42 PM
Flipster1988's Avatar
Car: 1988 Iroc-z
Engine: 383
Transmission: Tremec TKO 600
Axle/Gears: Ford 9" 3.70
I have the spohn crossmember with a TKO. ran into no problems. I used the lakewood bellhousing and it is setup to except the T-5 or TKO. My understanding is that the adapter plates push the trans back about an inch. If you need the bellhousing part number let me know, I will dig threw my reciepts.
Old May 28, 2006 | 09:51 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Getting the bellhousing bore on center is a real PITA. I ended up modifying the trans mount by weliding up the slots for the bolts and relocating each slot a 1/2 inch. hopefully having the bolts off-center wont cause any issues.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Fronzizzle
Aug 17, 2015 02:52 PM
SiCkRs
Aug 8, 2015 08:12 AM
