Torque converter question
Old Jul 14, 2005 | 10:41 PM
Texas_Rdz's Avatar
Car: 1989 IrocZ convertible
Engine: 305 tpi
I have an 89 Iroc Z convertible with a 305 tpi motor. I'm having problems with the motor stalling while it is in gear. I had a mechanic tell me that the T/C is not disengaging and its putting to much of a load on the motor and killing it. It happens when it gets warm , and driving around town. It drives perfect on highway and idles fine. Just when I come to a stop light it boggs down and dies out. Any help with this? Should I change the torque converter out? I have had the egr , o2 senser, fuel filter, idle air control, all changed out and he's pretty sure, that it is the T/C do ya'll have any suggestions?
Old Jul 14, 2005 | 11:25 PM
sixpackmtrspts's Avatar
yup sounds like the tc to me too. if a lock up converter does not unlock when you come to a stop sign its like stopping without pushing in the clutch on a manual trans car, the engine will stall. may have a valve in the trans sticking, but first check your stitches onthe brake pedal, theres switches on the pedal that are supposed to realeasa ehe lockup converter.
Old Jul 14, 2005 | 11:30 PM
Texas_Rdz's Avatar
Engine: 305 tpi
Could you tell me where the switches are located ? I'm sorry I'm a novice , just need a little guidance. I did the coolant bypass and took the screens out of the maf with the guidance on here. So I can do the work if I have a visual..lol Thanks for your help.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
