looking into new tranny
Old Jul 18, 2005 | 01:37 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Im looking for a transmission that will bolt right in place but it will be automatic and will have the manual shifting thing w it like the tipronic or w/e the f they call it now adays. anyone know if they sell this or does anyone have this?
Old Jul 18, 2005 | 03:07 PM
CrazyHawaiian's Avatar
Car: too many ...
Its called a manual valve body and you can get em through summit or jegs or any local speed shop, or any local rebuilder.
Old Jul 19, 2005 | 12:06 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You can set up a TransGo shift kit like this in a 700R4. If you want a whole trans, ready to run check out www.700r4l60e.com Pro-Built can build you one like that ready to go.
Old Jul 19, 2005 | 01:20 PM
Engine: LO3
so the trans-go shift kit will allow me to shift gears with the shifter but w and w my stock tranny? and how much would it cost roughly?
Old Jul 19, 2005 | 02:39 PM
You can set the TransGo kit up to allow either a manual shift override, or as a full manual, which will only shift up or down when you move the shifter. I like the manual shift override. It will shift normally when you put it in D, but if you want to shift it yourself it will hold the gears until you manually shift up or down. I think the kit is about $150 maybe. I've never bought one by itself. I get them in a whole rebuild kit from Pro-Built. If the trans is in good shape just install the kit, which I think also has a set of Vette servos, which are also a good upgrade. If you've got room to work and you take your time you can easily install a shift kit. Figure on a whole Saturday if you've never done one before. Make sure to keep everything very clean.
You can also tailor the RPM of the full automatic shift by changing governor weights. B&M makes a kit for this. I did this to get my Blazer to shift at 5,500 RPM instead of 4,500 RPM. That way I don't have to mess with installing a floor shifter, and don't have to worry about the lack of precision in the stock column shifter. However, with the TransGo kit I can still hold 1st gear for compression braking on hilldescent (while 4-wheeling), or downshift manually to help slow down in mud (where brakes don't really work so well).
Old Jul 19, 2005 | 02:56 PM
Engine: LO3
so let me get this correct i can get my auto tranny to act almost as a manual w/o a clutch full time? and would i have to change the center console or the shifter plate?
Old Jul 20, 2005 | 08:51 AM
Yes, exactly. You could use the stock shifter I suppose, as all the difference is in the trans itself. Most people opt for a ratchet shifter though, and I believe that B&M makes one that will fit right in the stock console. Do a search on thias forum and I'm sure you'll find info about it. I don't want to give you advice about it, because I've never installed one in a 3rd gen.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
