Stiff clutch, can't find answers!
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Axle/Gears: Moser 12 bolt/3.73
I got my ride about two months ago. (89 Camaro with a nice strong 355) The guy that built it put a small block into a V-6 chassis.
He installed in a Hays racing clutch assy. with a Lakewood bellhousing. He used the stock clutch master cylinder and pedal.
Now the problem; the clutch pedal is very stiff, and the clutch completely disengages at about 2/3 travel.
Do I need a different slave cylinder that is larger in diameter that will allow for a different master to slave cylinder ratio?
If a larger slave cylinder is needed, do you know where I can procure one for the Lakewood bellhousing?
Any other ideas of what is going on, or a fix?
Thanks in advance for your help,
Russell.
Russell.
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Do you know if he changed the cluch over to a 10.5 or did he use stock type 9&5/8 th's clucth to match the v6 tranny . If it's a raceing clucth for the 9.5 this may be why it is stiff . I am not formilure with what's avaliable for the that clucth size. If it feels like something is not right then you are probley correct . Sorry could not be more helpful Good Luck .
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
The clutch is a Hay's 11in. The tranny is a T-10, I dont think that matters though. Thanks for your help RocBoy.
PLEASE...I need help!!
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
ttt
Is this problem so stupid that I should just allready know the answer
, or does no one know whats going on?
, or does no one know whats going on? Member
Car: 85 IROC Ht
Engine: 383 carb
Hay man I can't belive no one has help't you yet . Now I want to know the answer too . I wonder why it is so stiff however it dose not sound like it is not moveing all the way in eather .I assoom that you are you useing the stock slave .What cars came with the T-10 with a hydro slave or was their any . Maybe you can find a doner one and give it a wirl . Once agian sorry I cant be more helpfull .
rsrmoore
Aug 7, 2015 08:44 PM
