transmission problems
Old Jul 21, 2005 | 12:01 AM
mavericsan's Avatar
Car: 89 IROC
Engine: 5.7 TPI
my car shifts from first to second at 20 miles an hour.but won't shift to third gear.at 30 miles an hour,the rpm goes up but don't shift.please help.
Old Jul 21, 2005 | 11:47 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
If you have checked the fluid level, checked the kickdown cable adjustment is correct, checked the selector lever cable adjustment is fine, then i would say your box is going to need an overhaul.
I'm sure someone will add a few other things to test, but auto boxes are a bit of a speciality repair.
Old Jul 21, 2005 | 11:52 AM
mavericsan's Avatar
Car: 89 IROC
Engine: 5.7 TPI
i changed the transmission oil and filter.i'll check what you told me to do.thanks.
Old Jul 27, 2005 | 04:32 PM
mavericsan's Avatar
Car: 89 IROC
Engine: 5.7 TPI
check all the cables and are ok.i notice my oil pressure is at 60.could that be part of my transmission problem.thanks
Old Jul 28, 2005 | 12:59 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Do you mean the Auto box oil pressure btw?
Old Jul 28, 2005 | 09:24 PM
mavericsan's Avatar
Car: 89 IROC
Engine: 5.7 TPI
the oil pressure,not the transmission pressure
Old Jul 29, 2005 | 08:32 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: transmission problems
Hi pal -- keep the old clutch packs when the trans gets rebuilt, so we can see the damage. Chat soon....
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
