wont go in gear...
Old Jul 29, 2005 | 02:48 AM
Wicked3rdgens's Avatar
Car: at the moment 92RS
Transmission: m5
wont go in gear...
hey yall i just had the clutch master and slave cylendar replaced and now i cant shift into any gear when the car is on. alot of resistance. and when i try to put it in rev. it just grinds. it did this a couple times in first gear when i first got it back, but then it stopped. does anyone know what this could be?
thanx
justin
Old Jul 29, 2005 | 11:00 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Can you get it into gear easily WITHOUT the engine running?
Ie, does it go straight in no problems?
If it does, then i would suggest the clutch pressure plate has a problem.
Old Jul 29, 2005 | 11:11 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
did you hav eit replaced, or did you replace them yourself?
sancho
May 17, 2012 10:49 PM
88fastgta
Jul 1, 2008 11:00 AM
easySPEEDcamaro
Oct 26, 2003 08:33 PM
nathan2003
Sep 20, 2003 04:07 PM
