Possibly switching to manual...found this on eBay
I've heard that it's much easier to go to a yard and strip a car that is stick in order to get all the parts for a manual swap rather than trying to piece it together. I found this on eBay though and was wondering if you guys think this would actually be worth bidding on. Looks like it's everything but the trans itself. Would I be paying that much to piece it together or to go to a yard and strip all that off? Thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
must just be my x-member then.. the bolt holes do not line up the same as the one on the t-5 in the z28. eh oh well. prolly one of those factory errors or somethin.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Eh at a junkyard the parts will probably run ya something like :
20 pedals
20 flywheel
10 shift plate
25? master and slave
20 pedals
20 flywheel
10 shift plate
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Around here pedals fetch $50, flywheel $50, hydraulics $35-$50, interior stuff maybe $20 for all of it. If the flywheel cna be used on your engine I'd say go for it. You just buy it and get it shipped. No crawling around wrecking yards gettign dirty.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The flywheel is not correct. That is a flywheel for a T56. It won't work for a T5, and that bellhouseing wouldn't work for a T56. I also think it's too much money....even IF the flywheel were correct.
-Tom
EDIT. Maybe it is a proper flywheel. Hard to tell from the pic, but it looks a lot like a T56 unit to me.
-Tom
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 5, 2015 07:57 PM
