Just got 1983 Trans Pace car=Problems
Old Jul 30, 2005 | 04:55 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Well, I went and picked up the car and started driving home. Got about 5 miles from the house the car made a noise and it wouldn't move. There is no drive gears and no rev. Can the trans just go all the way out at once? Also I put the car in gear and left it run and the drive shaft wasn't moving. It most be the trans, I never heard of it going all the way out at once. It drove fine up until that piont. Also the car sat for 2 years before I got it. Is there maybe something small in the trans that needs replaced?
Old Jul 30, 2005 | 11:48 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
well, i had a poorly adjusted tv cable & wrong fluid pressures in my tranny, and it would drive fine when cold, but as soon as it warmed up i lost all gears. could still coast, but nothing else. so yes its entirely possible, and while i'm far from an expert on auto trannies, it definitly isnt a good thing(to point out the obvious). it might be your tv cable, it might be something inside the tranny. regardless, there is probably a good chance something inside was hurt by the badness. ill leave any actual diagnosis to someone who actually has knowledge about auto trannies. (and not just limited experiences)
Old Jul 31, 2005 | 12:46 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Does the tranny have the propper fluid level...and was anything done to it after sitting two years...or did ya just start it and go...?
Old Jul 31, 2005 | 12:57 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I had a tranny do the same thing, no gears at all all of a sudden. Turned out the thing was worn out enough on the inside that when the tranny was cold the next morning, everything worked fine. As soon as the fluid warmed up, Nothing! I changed the fluid and set the tv cable but it didn't help. I tore it apart and the clutch plates were fried in the forward clutch packs really bad and the others about halfway. Hope this helps.
Old Jul 31, 2005 | 06:47 AM
buffaloman's Avatar
I'll go out this morning and see if it will move. Also nothing was do to the trans before driving the car. It was this car
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
I got it for 1,000.00 and it only has 68,000 miles not 132,000
Old Jul 31, 2005 | 05:59 PM
Naft's Avatar
havent torn apart my tranny yet(just got it out yesterday), but i bet it was my clutch packs too. i drove it for a few months on horrible internal fluid pressures before they went out(was just driving til it broke so i could put a manual in, the whole time i was driving i only had 1st and second anyway). you're lookin at a rebuild.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
hokis
Aug 9, 2015 03:57 PM
