B & M Fluid?
Old Jul 31, 2005 | 09:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
B & M Fluid?
Can the B&M Trick Shift tranny fluid be used in the 700R4? It doesn't say anything on it about Dexron/Mercron, or any of the other fluid specs that most fluids publish on the side of the bottle.
The website does say "for 1993 and earlier transmissions", however it also says "not recommended for electronic controlled transmissions".
The Synthetic Trick Shift says for "2000 model and earlier", and does specify Cexron/Mercron III.
I have a 1992 700R4, however I am disabling the ECM and using the aftermarket T/C Lockup Kit. Help.
Old Jul 31, 2005 | 10:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't bother with that crap. If you feel you really need to use it, save your money and use Type F fluid. It's the same stuff, without the magic blue dye that B&M puts in so they can charge more for it.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
