T/C Lockup - Why Lock or Not Lock?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I am in process of disabling my ECM, and installing the T/C lockup kit. My kit has the option to connect in-dash switches to either:
A) Lock the T/C in 2nd or 3rd instead of only in 4th
B) Never lock the T/C
They explain that I might want the T/C locked in 3rd while towing (how much of that do we do?)
Before I start wiring - What's a more "practical for a street car" explaination as to why I would either want to lock the T/C in a lower gear, and also why I would not want it to lock at all?
Thanks.
Thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can lock it in 3rd if you'll be cruising in that gear for an extended period of time. You can prevent it from locking in 4th if you'll be pulling up a long hill or something at a throttle opening where the tcc might be cycling on and off.
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
