KICKDOWN, TV adjustment on 305 TPI
Old Aug 5, 2005 | 08:35 AM
bills2north's Avatar
Car: Silver`85īT/A T-top
Engine: 305 TPI, beefed cam, fast chip
Transmission: 700 R4
Hey guys!
When I stomp on the gas, motor revs in between gears but doesnīt engage until rpms go down and "catches" in 3rd(?). In other words no kickdown. Otherwise it changes gears smoothly in all conditions.
Haynes book reads to adjust kickdown, press release tab on TV adjuster. Then the cable corrects the tension itself. Is it really that easy???
Next thing. Birdīs starting to backfire. Sounds more like burping. It happens when I press the gas a little more before it changes gear. Sounds like it might be related, ie starves itself since it wonīt downshift.
Btw, Iīve admired this site for a long time. I found you guys in 2000 when I got my 1st f-body. Black 86 Z28 LB9 T-top. Now I have a T/A. Itīs a fine machine too. Iīve learned alot- THANKS!!
Now Iīve finally joined
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
