Electronic VSS Auto vs 5 speed info needed!
Old Aug 7, 2005 | 03:56 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hey guys, I haven't posted here in a while. I am planning on running an Autometer electronic 200 MPH speedometer in the car. I had a few posts earlier about it and I understand that the electronic VSS will be enough to run the gauge. I do have a 5 speed though. I have been to all the junkyards in my area to find an electronic VSS from a 5 speed f body. I have had no such luck. I did, however, find some automatics that have an electronic VSS. Can I use the VSS from an automatic? Will the auto VSS fit in the hole for the 5 speed? As of right now, I am using a cable driven speedo(the car is an 88 and was a v6 originally) Any info would be greatly appreciated. Thanks, Paul Moore
Old Aug 7, 2005 | 04:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, an automatic VSS is larger than a T5 VSS, and will not fit.
Can you still order one from GM? How about other aftermarket T5 companies? Make sure you dont get a Ford one.
Old Aug 7, 2005 | 06:05 PM
paulmoore's Avatar
Thanks for the quick reply! At least now I know that I definitely have to use a VSS from a 5 speed. That narrows it down significantly. Thanks, Paul Moore
Old Aug 7, 2005 | 07:42 PM
paulmoore's Avatar
Is this the one that I need? A very thoughtful member of this site is willing to help me out but I need to make sure that this is the right VSS for a 5 speed. It looks like the right one to me but I'm not positive. Here is the pic....
Old Aug 7, 2005 | 10:04 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
That looks like the one to me. Make sure you've got the right gear on it. Also, FYI, they are available through AC Delco. That's where I got my VSS and the proper gear when I did my T5 conversion
Old Aug 7, 2005 | 10:11 PM
paulmoore's Avatar
NastyL98_T/A: I am not worried about the gear that is on the VSS because the speedometer that I will be using from Autometer is one of those self calibrating units. I just needed to get the electronic VSS to use as a sender for that speedometer. Thanks for the info. Another problem solved you guys are great! Thanks again, Paul Moore
Old Sep 18, 2005 | 02:34 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Any idea what the part number is?
IROCZ1989
Jan 24, 2016 03:55 PM
mizz0313
Aug 12, 2015 06:45 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
