Gear ratio numbers
Old Aug 7, 2005 | 09:36 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
Axle/Gears: 9 bolt 2.77
Gear ratio numbers
I read somewhere that the gear ratios are stamped on the driver side axle tube is this true? Can someone post a picture of what they look like cause I cant see mine?
Old Aug 7, 2005 | 10:06 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
No, the axle code is stamped on the right-side axle tube, not the ratio. Try brushing away the road grime if you can't spot it.
The first three digits are the actual axle code.
Sorry I don't have a picture, but there's a decent one in the Haynes manual for Firebirds under the Clutch and Driveline chapter.
HTH
Old Aug 7, 2005 | 10:22 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
I ment axle code. So its on the passenger side axle tube.
Old Aug 7, 2005 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The axle code is stamped on the front of the passenger side tube near the center section. A wire brush is usually needed to find and read the code. The code can tell you what was originally in the diff but doesn't mean that's what's in the diff. At any time in the car's history the diff gears could have been changed or the diff swapped out from another third gen.
Old Aug 11, 2005 | 07:06 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
i won't be able to see my bird for another two weeks but does the code tell you the spline count for the axles?
Old Aug 11, 2005 | 09:12 PM
Jade Grey's Avatar
Engine: 305TPI
The changeover from 26 to 28 spline axles happened in the middle of the 1989 production year. I do not think the axle code will help you in determining spline count.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
