9-Bolt Axle Seal Installation Question
Old Aug 8, 2005 | 12:49 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
What is the proper way to seat the axle seal on the BW 9-Bolt??
I pulled my axle to put in the PBR calipers/rotors and want to make sure my seal is seated, so I don't get leaks.
I did a search and came up with no details for this specific question. The response will help all 9-bolters that do this mod or when installing new seals.
Photos would be great if you have any.
Thanks in advance,
Scott
Old Aug 9, 2005 | 09:57 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Do not know if your 9-bolt is the same as my 10-bolt , It took the the old axle bearing place't it between the seal and beat it on with large rubber malet . You can use any thing just try to make it go in evan .
Old Aug 11, 2005 | 10:47 PM
gearhead 88's Avatar
If your car didn't come with the 9 bolt I would advise you to make another dicesion . You will not be able to find any replacement parts for it and the ones you do will be extreamly high. And good luck on finding any useable used parts
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
