Megashifter won't adjust properly.
Old Aug 9, 2005 | 11:50 PM
ktacam's Avatar
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
Put the trans back in my car, and I have spent hours trying to get the megashifter adjusted, I can't get it. When I attach the cable to the manual valve link the shifter becomes a pain to move and will not go into all ranges. When disconnected from the manual valve link the shifter goes to all ranges easily. The end of the cable moves in and out of the manual valve link in park and reverse easily as required. I ran the trans through the gears at the manual valve and the ranges work fine. Its almost like the cable becomes kinked or something when its installed. I have the cable bracket on the correct bolts. I am also using the first hole on the L shaped manual valve link with the bottom part of the L facing the front of the engine. What did any of you use to space the link? Running out of ideas. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
camarohelp
Sep 22, 2015 03:19 PM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
