Ground clearance problems with a TKO?
Old Aug 13, 2005 | 09:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ive heard that ground clearance can be an issue with the TKOs because they hang down a bit. How bad is it?
Old Aug 14, 2005 | 10:52 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
There's just one part of the casting of the case that hangs lower than the crossmember. Crossmember is spaced down from the frame 3/4" to fit it in there.Drags on speed bumps if I take them too fast. My car is lowered over 1-1/2".
The trans is pretty tall compared to the T5. Also since it's mounted vertically instead of at the angle the T5 mounts at, makes it a pretty tight fit.
It hasn't really been much of a problem, though.
-Rich-
deracer
Apr 11, 2016 12:04 AM
Bryan F
Aug 27, 2015 07:28 AM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 17, 2015 02:52 PM
sreZ28
Aug 14, 2015 07:48 PM
