Easy switch to posi?
Old Aug 15, 2005 | 02:51 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If I shake my rear tire back and forth (sort of like checking wheel bearings on the front) I get a lot of slop. Something tells me this isn't good and my rear diff may be about to die. I currently have a '91 RS with the stock non-posi rear. So question is, if the rear does go out, is it easier to buy a replacement used posi/disc setup from a wrecking yard, or is there some kind of LSD module that I can just bolt up inside the stock diffrential housing? I've not played much with rear diff's so any help would be great!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Dkelz313
Apr 7, 2016 10:38 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
