5 speed swap
Old Aug 18, 2005 | 02:05 PM
Hanny's Avatar
Car: 1986 Camaro
Engine: 2.8L
Transmission: 5 speed standard
5 speed swap
Hi,
My '86 Camaro with a 2.8L has developed a grinding problem in the tranny when i downshift. Looks like time for a tranny replacement. Could anyone help with what models and years of 5 speed transmissions will bolt in place? Just so I know when Im browsing the scrap yards. Thank You!
Old Aug 18, 2005 | 10:11 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
any 82-89 camaro v6 tranny or any 82-85 firebird v6 tranny should work with your speedo. other than that any v6 3rd gen transmission would work, but you would need to swap out the vss in the tailhousing for the mechanical setup that you have.
Old Aug 18, 2005 | 11:48 PM
Hanny's Avatar
Car: 1986 Camaro
Engine: 2.8L
Thanks Naft
Thanks for the reply. On further investigation it just may be the pilot bearing making the noise. It started when I downshifted into 3rd. Now its happening in almost all gears even when the clutch is depressed. Oil level looks ok and fairly clean. Think I may have found the problem, but pulling it and inspecting is probably the only way to know.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
