manual shifting an 700r4..hurt anything?
Old Aug 21, 2005 | 11:20 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
when my car is cold my shift points are at like 3 grand so...ive been shifting it manually. i go 1st,2nd, then drive or over drive. is that bad to do with my transmission. ive got a b&m trans pak shift kit witch, i guess, explains my wierd shift points. when its warmed up, its fine. shifts where it should. i adjusted the tv cable (it had so much slack) it made a little bit of a difference...maybe its disconnected at the trans? sorry about the mulitple questions...thanx for helping in advance
Old Aug 21, 2005 | 01:09 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: manual shifting an 700r4..hurt anything?
If it is disconnected at the trans, reconnect it. If it is stretched, change it. An out of adjustment tv will guarantee a future rebuild.
Old Aug 21, 2005 | 11:12 PM
Car: 1985 iroc-z
i adjusted it yesturday. it seems 2 be tight. but i still have the wierd shift points when its cold. shift kit throwing off something at the computer?? im clueless with this.
Old Aug 22, 2005 | 06:59 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Generally speaking, shift points are controlled by the governor. You can remove it, clean it with carb cleaner, make sure the valve in the center moves freely etc. Inspect the gear and replace it if nescessary. You can buy just the gear if needed. You can also buy a complete governor if needed.
Old Aug 22, 2005 | 09:29 AM
Car: 1985 iroc-z
is any of that to hard to do? my car has a b&m trans pak in it. perhaps the gov and springs and wieghts were changed along with that and this is all just the shift kit? also..when i did the tv cable i made it tight...i didnt adjust it by goin WOT after i made it tight. im at work now..im gonna work on it in the parking lot. im going to do it like it should have been done the 1st time
Old Aug 22, 2005 | 01:34 PM
Car: 1985 iroc-z
YES I GOT IT!
the ratcheting adjuster on the cable has been stuck half open. even when i adjusted it i didnt engage it all the way. i broke it loose by pressing hard with a piece of metal and i got it adjusted and now its perfect! revs high when i hammer it, shifts normal when its cold...its great...im glad thats all it was
Old Aug 22, 2005 | 03:35 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Good news
junior419
Apr 7, 2025 11:35 AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RyanJB
May 7, 2016 06:23 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
camaronils
Sep 20, 2015 02:57 PM
