scored (what I think) is a TH200-4R - build/install options help needed!!
Old Aug 23, 2005 | 12:50 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
I got this tranny out of a Chevrolet pickup recently - looks to be in very good condition - oil clean and reddish brown
it had a throttle valve cable similar to my 700R4 - a square pin plug connector on drivers side with three pins operational - fourth blank - the body of transmission is one complete unit - no extension piece at tailhousing like my 700-R4
and it has a tag riveted on at tailhousing on passenger side
# ON TAG: 222-IT850G0273
# ON SERVO COVER: LESTER-5 8635692
#ON TOP BELLHOUSING(LARGE PRINT): 402 X
#ON L.SIDE BELLHOUSING :HYDRAMATIC 864340005
Can you help ID tranny and possibilities for running in my 85 camaro
what spline main shaft and tailshaft?? ( i did not retrieve d/shaft yoke from pickup) and what interchanges can be made between 30 spline convertors and d/shaft yoke for 700R4 which is presently on my 85 camaro
what recommended build ups for manual shift install??
any help on way forward would be appreciated
Old Aug 23, 2005 | 01:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
check out this thread to help find out which trans you got.
https://www.thirdgen.org/techbb2/sho...hreadid=316255
Old Aug 23, 2005 | 03:16 PM
Engine: 383ci chevy
Thanks for thread - it is a TH200-4R - so now - what can be done with it ?
Is it worth it to build up a TH200-4R as opposed to a TH350 - for when my 700R4 finally packs it in??
Old Aug 23, 2005 | 04:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's some guys on the C3 corvetteforum running into the 11's with the 200, seems they like it better than the 700 for the first to second gear split. The OD is the nice thing over the TH350.
From what I've gleened, looks like they are paying about 2K for the tranny from Art Carr and his new company (PT-something)...supposedly bulletproof...but, since you have all the hard parts, you have to be a few good bucks ahead.
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
