What type of lube for a T-5 transmission?
Old Aug 23, 2005 | 04:37 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Do I use tranny fluid or gear oil? and what type?
Old Aug 23, 2005 | 05:36 PM
jimmy_mac's Avatar
Regular T5 gets gear oil, World Class gets ATF. Do a search for specifics. It's on here. That's where I got the info before filling up mine.
Old Aug 23, 2005 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
More fun. I say that because not even GM knew what to put where. The shop manuel for my 85 IROC (non-WC, of course) says ATF.
JamesC
Old Aug 23, 2005 | 08:58 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
JamesC is right, its ATF aka Dextron. I work in the field and I have Alldata. GM specifies Dextron. You can use gear oil if you desire. It won't damage your trans,that I know of. I have tried Gear Oil in the trans, its ok in the summer. The syncronizers stick in the winter with Gear Oil, well at least until its warm. My advice, if you want something better that stock, use synthetic ATF(Mobil 1)or use BG Syncro Shift.
OneBadZ4U
Old Aug 23, 2005 | 10:15 PM
sellmanb's Avatar
Car: '86 Berlinetta
I never knew this before, good info! The books at my work say it uses 85w90 GL5 guess i'll have to scratch a little note in there lol.
Old Aug 24, 2005 | 12:32 PM
jimmy_mac's Avatar
Hmm, I did not know you could use ATF in the NON WC. I think I would use a synthetic ATF having that knowlege. I am pretty sure though that you cannot use gear oil in the WC T5 due to the thickness of it and the redesign of the synchronizers and other parts in the WC model.
Zane Story
Oct 8, 2015 12:40 PM
64Chief
Sep 12, 2015 08:05 AM
DARKmj16
Sep 9, 2015 04:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
