Torque arm mount busted, can this cause 80mph+ vibrations?
Old Aug 26, 2005 | 01:39 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
If any of you have been reading my posts, and I thank you for giving me some pointers, here's a little update. I jacked up the car and noticed that the mount that attaches the torque arm to the tranny is cracked and dry-rotted. Obviously this may, most likely is causing my "shift into gear/reverse-"CHUNK sound". But can it cause vibration above 80mph?
Something else to think about here, my rear sway bar endlinks are dryrotted and non-existant on the passenger side, and my car is in need of an alignment. Do you think that all of these combined will cause a vibration above 80mph? I have just today ruled out U-joints.
Old Aug 26, 2005 | 10:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I wouldn't be surprised. At any rate, your problems require a fix. Try poly.
JamesC
Old Sep 12, 2005 | 09:16 PM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Those problems certainly don't help. Replace all mounts or links that need replacing and have tire balance checked.
morrow
Jan 13, 2024 12:29 PM
deracer
Apr 11, 2016 12:04 AM
angel2794
Sep 8, 2015 06:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
