Rocking/Stumble When Accelerating In Gear
Old Aug 27, 2005 | 08:28 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Just got my second engine swap done on my Camaro, took it out for one quick ride. The biggest problem is when I start to accelerate and stay in any gear for a while, the car will start to jolt back and forth, like when your in to low of a gear, but its happening when Im at over like 2500rpm (my Summit tach stopped working so I dont know the exact rpm) I had a knew U joint put in my driveshaft(back one) Last year the car would vibrate in certain speeds at certain rpms. Whats are some possible causes?
Old Aug 28, 2005 | 08:05 AM
Car: 1988 Camaro
Engine: 350 V-Eight
My ideas are:
Driveshaft not at correct angle. We modified the V6 T5 cross member to use a V8 tranny mount. That was last year, but the car wouldnt do this jolting back then.
Driveshaft no good, needs rebuilt.
U-joint installed incorrectly.
Would one (or all) of those causing this type of wierd movement?
Old Aug 28, 2005 | 10:28 AM
Car: 1988 Camaro
Engine: 350 V-Eight
Should there be any play in the driveshaft between the bearing caps the retaining straps go over? Mine is able to move side to side a little.
Old Aug 28, 2005 | 07:40 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I retightened the driveshaft, took the play out of it I think. But the car still bucks after a while in second and third gear. Once I throw it in neutrel it stops. I cant believe no one has given any suggestions yet.
Old Aug 31, 2005 | 06:59 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Could it be the engine itself hunting around on part throttle?
Old Aug 31, 2005 | 12:05 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Figured it out. Engine just has a higher powerband
88rscamar0
Sep 23, 2015 09:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
