9 bolt leaking need help!!!
Old Aug 28, 2005 | 09:34 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I know of 2 ways to fix this but i want your input.
1st is to clean and silacone the axle tubes.
2nd the best ( I think) is to remove and clean the rear, have a bead welded around the axle tubes.
Please give your input on these 2 fixes.
Thanks Randy
Old Aug 31, 2005 | 03:21 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
weld it
Old Sep 4, 2005 | 04:59 PM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
9 bolt leaking
A leak in the axle tube of a rearend means it is cracked. Find a reputable welder
Bubbajones_ya
Aug 31, 2015 12:02 PM
mike_c
Aug 27, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
