T56 and LT's
Old Aug 28, 2005 | 10:09 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
T56 and LT's
Just did like 40 minutes of searching and really didn't find what I was looking for. Basically, I am about to do a T56 swap into my 91Z that has hedman LT's on it. will I run into any clearance issues with the tranny and headers? Any people running hedmans with the T56? Just looking for some confirmation.
Old Aug 28, 2005 | 11:13 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
How do you have you exhaust routed after the LT's?
Old Aug 29, 2005 | 08:00 PM
305RSlc's Avatar
Well it comes off the x-tensions that hedman has to clear the floor and x-member. Goes into a kind of T-pipe right after the x-member then into an I-pipe that runs down the pass. side ds tunnel and dumps right before the rear axle. I can fabricate the exhuast after the collector...just wondering if I'll run into interference between the collector and clutch fork or bellhousing.
Old Aug 31, 2005 | 05:53 PM
305RSlc's Avatar
hmmm...no one?
Old Sep 1, 2005 | 01:01 AM
formula89383's Avatar
im running hedman tork-step long tubes in a 89 formula firebird. i just grinded on part of the 3 bolt flang and clearanced the bellhousing no big deal, if you can convert to a 6speed you can make it fit. mine did have the spinning flange on the header, a solid flange would probably be a pain.
i know the spinny flange works
later,
Jon
Old Sep 1, 2005 | 07:58 PM
305RSlc's Avatar
Tork Step are just about the same as the regular LT so maybe I'll get lucky. I'll let ya'll know when I get it done just so if this comes up again, someone will hopefully pull it up in a search.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
