How to replace pinned in U joints
Car: 2000 BMW M5
Hi guys, I am going to be using a chevy 27 spline yoke, conversion u joints, and a Ford fox body 45.5" driveshaft in my 2nd gen HSR'd 327 mpefi'd camaro with a newly installed T5 trans. Problem is I need to take the 27 spline yoke off the stock chevy driveshaft and install it on the Ford. I already have the correct U joints to adapt between chevy and ford parts, BUT how do I get the u joint out of the chevy yoke? It's pinned in. I will also need to reinstall the new U joint into the chevy yoke. I have access to a shop press but have no idea how the pins come out -- do you have to drill and destroy them to get them out or is there something I can do with ordinary tools to get them out in one piece?
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
same way you get any thing out of the yoke.. you have to press it out and then press the new one in...
Car: 2000 BMW M5
I'm talking about the "non-serviceable" gm driveshafts that do not have clips retaining the U joints -- they have pins. I was told that these pins are actually a solder-type deal where they have to be heated to be removed. I think I may look for an older chevy driveshaft at a junkyard that has a yoke with the older style clips.
huh i dunno.. ever single one of the chevy driveshafts i have had have been press in and out.. huh.. even my 80' camaro all the way up to the 95 blazer..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're held in with injected plastic. Heat up the yoke with a propane torch until most of the plastic comes out the injection holes. Once most of the plastic is out, replace the u-joint as normal.
Car: 2000 BMW M5
Thanks guys -- If I can avoid crawling around under cars to find an older style yoke that would be nice. Okay so I know how to get the pins out now -- torch. What do I use to replace them, steel dowel pins? Does anyone know what size dowel to use? Or do I not need to replace the dowels (will the press fit hold the caps in?)
Car: 2000 BMW M5
Wow I can't believe the answer was that simple. On inspection, the replacement u joints do indeed use internal clips. Super! This was a lot less of a hassle than I anticipated. Thanks guys!
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
