Quick speedo gear change? check
Old Aug 30, 2005 | 11:34 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Quick and hopefully an easy answered question.
I have a 1991 Firbird w/ a 700 R4 transmition.
I swapped rear ends from a 2.73 to a 3.23.
Are the Grey 15 tooth drive gear and the Blue 38 tooth driven gear the correct combination to use for accurate speedometer readings?
Thanks a bunch guys,
Jim
Old Aug 30, 2005 | 12:11 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Your GM parts place sould be able to tell you in about 5 minutes if it is or not lol.. they have a ratio calculator for it.. and also you will need to give thm you tire size...
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
