what type of rear-end do I have
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
My car is a all stock 1989 IrocZ w/5.7 TPI L98, 4wheels discs brakes, and option G80 Positraction. DO I have a 10-bolt or 9-bolt in 7.625 or what?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can determine what rear end you have by simply counting the bolts. If you count 9 than you have a nine bolt and if you have 10 you have a ten bolt
. There is no telling what gears are in there now unless you pull the cover and check. Chances are your rear needs a fluid flush anyways.
. There is no telling what gears are in there now unless you pull the cover and check. Chances are your rear needs a fluid flush anyways. Thread Starter
Car: '87 Iroc-Z
Okay. That helps but what about the type? 7.625, 7.75, 7.6 or what? someone else please!
You have a 7.5" rear end. The fourth gens had 7.625" Here's a list of RPO codes for you, they should be in the center console lid. Look for these numbers to tell you the ratio of gears.
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
GW6 - 3.27
GM3 - 3.45
GT4 - 3.73
G80 - posi
G92 - performance
The G92 means you have the optioned gears. For example, if you see the RPOs GU6 and G92, then it means the gear size GU6 (which is 3.42) was an option. But if you see GU2 and no G92 then it means you have the normal factory 2.73 gears. G80 means you have posi like you said.
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
GW6 - 3.27
GM3 - 3.45
GT4 - 3.73
G80 - posi
G92 - performance
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
GM switched from 7.5" to 7.625 around 1986 but they're still called a 7.5" diff. The only difference was the slight increase in ring gear size. Everything else stayed the same.
Car: '87 Iroc-Z
So to get new gears. Get the for the 7.625
I dont have any of those except G80. I have GH3
Car: 87 IROC L98
That doesn't mean that's the diff in the car. That's just what was in the car when it came from the factory. A previous owner could have easily installed a 10 bolt in the car if the 9 bolt failed and he found parts for it were expensive or non existant.
Climb under the car and look at the rear cover on the diff. A smooth cover is a 10 bolt (count the bolts). If there's a rubber plug in the cover to fill with oil, it's a 9 bolt (count the bolts). Extremely rare and strong and didn't come in any factory car except the SLP Firehawk is a Dana 44. It will have 10 bolts and a metal plug in the rear cover.
You're not going to find many suppliers with 9 bolt parts. Your best choice is www.9bolt.com
MrPackstin
Oct 25, 2017 08:09 PM
