Need info about B&M megashifter w/ stock shifter cable!
Old Sep 3, 2005 | 12:37 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I know this has probably been addressed in previous posts but since the Archives are not working, I have to post my question.
Ok, here's the deal. About 4 years ago I bought a B&M megashifter which comes with the 5ft B&M shifter cable. Just today, on my way home from the parts store, my cable broke. After 4 years of manually shifting an automatic, it probably was the cause of the busted cable. Now I'm looking into a replacement cable.
Question is ... should I fork out the cash and buy the replacement B&M cable or will the stock GM cable work with that shifter?
Additionally, even if the GM cable does work, is it as strong and will it last as long as the B&M shifter cable?
Old Sep 3, 2005 | 01:11 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the factory cable will not work with the b&m shifter. they mount up two different ways. i could be wrong but i think they cost about the same.
Old Sep 5, 2005 | 12:00 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Need info about B&M megashifter w/ stock shifter cable!
Do you think a cable that last 4 years is strong??? my GM cable is 20 years old and it still one piece. There is nothing better than the OEM.
Old Sep 5, 2005 | 03:17 AM
Re: Re: Need info about B&M megashifter w/ stock shifter cable!
That may be true but you have to realize that the B&M is a ratcheting shifter.... it's not going to be as easy on the cable as a stock shifter.
Besides that, do you manually shift your automatic? I do, EVERY time .... I never let it shift itself anymore.... it shifts too soon on it's own ..... plus the ratchet action is fun.
Fanatic1074
Oct 3, 2022 05:57 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
