$250 for a used 9 bolt?
Old Sep 4, 2005 | 11:39 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
A guy at my shop said hes got a used 9 bolt out of an IROC (I think) with disk brakes. Thats the main thing that got my attention, DISCS!! But, 250 for a 9 bolt? that sound about right? I think he said it was a stock posi, but gears were like 2.XX. Any advice? Is it worth the time/money to get it and throw in 3.73s rather than rebuild my stock 10 bolt/drum rear?
Old Sep 4, 2005 | 11:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the availability of the gears first.
Old Sep 5, 2005 | 12:16 AM
spills's Avatar
Car: 89 RS
Thats something else Ive seen, it seems that it would cost more to build up a 10 bolt than a 9 bolt.
Old Sep 5, 2005 | 12:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm sure you mean that the other way around.
Old Sep 5, 2005 | 03:55 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I wouldn't give more than $100 for a 9 bolt with those gears, which are 2.77s by the way. From what I have found, for a new posi unit, new 3.73 gears, and the install kit you're looking at $895 shipped. You can get just the 3.73 gears with the install kit for $475 but it won't do you any good without the new posi unit. The 2.77 uses a series 2 posi unit, and the 3.73s have to have a series 3 posi unit. The 3.73 are special gears for that rear by the way .... the factory 9bolts came with 3.70 gears IF you could find one.
Also, "strange engineering" has 3.70 gears for the 9 bolt for $319 plus $119 for the master installation kit.... but then you still have to find a new carrier because the 3.70 gears won't fit in a series 2 carrier.
Basically, unless you're really wanting the 9 bolt, don't waste your time. For about $1200 you can get a Ford 9" rear end ready to bolt in ..... that's only about $200 more than buying the 9 bolt and putting 3.73s in it ($100+$895) ..... that's IF you can manage to talk the guy down from $250 to $100
Old Sep 5, 2005 | 11:18 AM
spills's Avatar
Car: 89 RS
Ya, actually I did.
Ill ask the guy if he can come down some. Thanx for the input guys.
Old Sep 7, 2005 | 03:45 AM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
Mine blew up i think they arnt what there hiped up to be ya there a good replacement but the parts are soooo exensive if you can find them oh i have 3-27 gears for cheap, there still good my spiders and side gears are chewed up bad....
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
