I suppose this is very overdue, but...speedometer calibration
Old Sep 6, 2005 | 10:31 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
This is waaaay overdue but I think it's about time I tackle this issue
First of all my car is a 1991 base model Firebird with an L03 and 700R4.
Back in December I did a rear end swap on my car...my car came with a 2.73 open rear end and I put in a 3.23 posi rear end...since then my speedo has (understandably) been off roughly 10mph (higher or lower depending on how fast I am going), because of the gear change.
My question is...I'd like to re-adjust my speedometer to compensate for the gear change... how can I do this?
I've heard from some places that I'll need new speedo gears inside the transmission...from others I've heard it's as simple as a computer adjustment.
HELP! Thanks...
Old Sep 7, 2005 | 08:55 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You need atleast one new speedo gear if not two. I'll run the calculations later when I have more time.
Old Sep 7, 2005 | 11:34 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yes, all you have to do is replace the speedometer gear(s). They are located on the tailshaft of the transmission and on the VSS itself. Here's a step-by-step on how to replace them:
http://sethirdgen.org/vss.htm
Once you know what gears you need, just check out the FAQs on the main page for the GM part number list for the different gears. When you remove the extension housing to replace the gears, you should replace the 2 seals on it. The front o-ring seal, GM part number 1358899, and the extension housing oil seal, GM part number 8673526. If you want/need a new speedometer gear clip, it's GM part number 6261781.
Old Sep 7, 2005 | 12:33 PM
TJfive0's Avatar
Car: 2008 Toyota Rav 4
Engine: V6
Jungleman, where did you get your posi rear end from?
Old Sep 11, 2005 | 10:51 PM
JungleMan's Avatar
Engine: L03 :(
Got mine off eBay. I think it was $100 plus shipping (which was $150!) but I couldn't find anything local. The rear needed new rotors and pads but other than that has been problem free...actually looked less rusty than my old rear end which has spent 14 years under a NC car.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
