92 corvette 700r4 & 91 Z28 700r4 wats the difference?
Old Sep 8, 2005 | 10:05 AM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
ok i kno the corvette would diffenlty have a better version of the 700r4 but im in between 2 right now now what are the differences in the 92 corvette 700r4 n a 91 z28 700r4? and how much better ?
Old Sep 8, 2005 | 10:26 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Trans
The Corvette trans does not fit in a F-body, shorter rear shaft and no rear mount.
Old Sep 8, 2005 | 10:30 AM
MoroteZ28's Avatar
ah thanks man real good to kno that i guess 91 z28 tranny ill be puttin in my firebird
Old Sep 8, 2005 | 03:13 PM
MoroteZ28's Avatar
now that im goin wit the 91 700r4 does it have ne improvements or differences than the earlier yrs ?
Old Sep 8, 2005 | 05:04 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
i think the torque converters have a higher stall, and tighter springs for firm shifts.
Old Sep 13, 2005 | 04:47 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
Is there anyway to make the vette version fit the F-body?
I have a Rossler 700r4 from a 91 or 92 Vette, it has had a rear mount put on it to bolt up to an f-body.
But, I didn't know about the shorter rear shaft.
Old Sep 13, 2005 | 07:44 PM
8UpAFord's Avatar
Car: 1988 Corvette
Why not get your Z28 trans rebuilt?
I'm sure if you have the trans out you can have a trans guy tweek it for not to to much and buy you're own parts..
Not sure if what you're askin will work on the vette trans. I don't think it will work though without tons of work at least.
I rebuild my old 350Turbo trans in my 84 grand prix like 6 years ago. i drilled out valve body,removed check *****, installed a kick *** pump, and removed my wave plates, and a higher stall. It shift hard as hell, i had 4'11 rear end too then installed my stock 2.07 rear after because i was getting into to much trouble hahaha. I'd be on the gas 15% and be able to spin tires just like idleing into second gear. My rear end kept having problems like loose spiders and worn out spiders. But the trans lasted 50k then i sold the car. I love auto trans it's the way i've always gone. BTW with my 2.07 rear in i'd still smoke my tires shifting into second gear going about 50mph haha. people would get scared when i'd shift right next them.
damn sorry not get get of the topic or anything good times.
Frozer!!!
Jan 19, 2024 04:55 PM
kah992
Aug 19, 2015 02:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
