'85 3.42 ten bolt fit my '89 IROC???
Old Sep 9, 2005 | 07:31 AM
TJfive0's Avatar
Car: 2008 Toyota Rav 4
Engine: V6
I currently have a 1989 IROC with an open rear end, I think 2.73's. I don't know if it is 10 bolt or 9 bolt. I think it is 10 bolt.
I am curious if a 3.42 open 10 bolt rear would fit on my car?
Would it simply swap right in?
Also, I would eventually want to upgrade it to a posi. To do that would I only need a new carrier or whatever it is called for it? And with a new carrier, would I need a stage 3 or what?
If somebody could help me out that would be great.
Thanks,
Tony
Old Sep 9, 2005 | 03:20 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Re: '85 3.42 ten bolt fit my '89 IROC???
Yes.
Yes.Depending on what brakes are on the car,and what brakes the new rear is setup for?
Yes.Generally a rebuild kit is a good idea as well.You can do just the carrier with new bearings though.
Series 3?Depends on the gears you are going to get.
Old Sep 9, 2005 | 03:43 PM
TJfive0's Avatar
Engine: V6
Well the rear end i would be getting comes with no brakes, does that matter, or is it better?
As for a rebuild kit, I dont want that right now, if I wanted new gears, i would just do it to my rear end.
All i want is a new carrier and i guess new bearings. If i kept the 3.42 gears would i need series 3? Also if i eventually upgraded gears to 3.72's would i need a series 3 or bigger? how about 4.10's?
And when i do put posi in if i do, i will leave it at 3.42 gears.
If I put posi in and say in like 3 or so years i watn higher gears, can i just get new gears and replace them?
Old Sep 9, 2005 | 03:47 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Why waste your time & money on that rear. Spend some time searching for a 1989 9-bolt with the good set of rear brakes and the ratio & Limited Slip you want.
Old Sep 9, 2005 | 10:17 PM
TJfive0's Avatar
Engine: V6
I guess that is why I am posting this. I dont know much of anything about rear ends. All I know is that I dont have posi and I have 2.XX gears and that blows, lol.
But I am open to suggestions from everybody. And price ranges would be good too.
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
